Labor price?
Old Jan 18, 2008 | 11:40 AM
Leigh44's Avatar
Default Labor price?
I am not handy with carb. work and was wondering what people are paying a stealer to put on a slip on pipe, change air filter, and do rejet. I know it's not to hard, I just like being able to go back to someone if it's not right[img]i/expressions/face-icon-small-happy.gif[/img]!
Thanks
Leigh
Old Jan 18, 2008 | 02:43 PM
Leigh44's Avatar
just got a quote for $200.00 for rejet and mount slip on pipe. Fair?
Old Jan 18, 2008 | 05:18 PM
Raptor450's Avatar
I pay my stealer $45 an hour. It should take about 2 hours to do your job. If you know what a wrench is you should be able to do the filter and pipe yourself and just get them to rejet it and save yourself some $$$$$$.
Old Jan 18, 2008 | 05:21 PM
scootergptx's Avatar
Supersock
Hired Gun!
I agree, put the pipe and filter on, and let them do the jetting.
Old Jan 18, 2008 | 05:33 PM
Leigh44's Avatar
I was thinking the same thing after looking at the filter and pipe portion. I'll do that myself then have the stealer do the re-jet. Now whats this wrench thing[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 18, 2008 | 08:51 PM
ctateusa1's Avatar
I would definetly put the pipe on and the filter and let them rejet the carb if your not comfortable doing it yourself. With a dynojet kit you get instructions on how to do it and really all you need is a allen key to loosen the clamps on the carb boots a phillips screwdriver to remove the float bowl and a flat head screwdriver to remove and reinstall the new jets.
Old Jan 18, 2008 | 11:53 PM
Leigh44's Avatar
is there tuning involved or is it simply install new jets and go?
Old Jan 19, 2008 | 12:16 AM
Raptor450's Avatar
Like ctateusa1 said, if you buy the Dynajet kit it will come with instructions on EXACTLY what to do. The only tuning you will have to do is turn a screw on the carb for air mixture. The instructions will tell you how to set this screw for your application.
Old Jan 19, 2008 | 05:25 PM
Leigh44's Avatar
Not to beat a dead horse but, what would happen if I put on the pipe and filter with out the re-jet. And has any one ever done a video or ptures of a re-jet? Thanks
Old Jan 22, 2008 | 05:17 PM
imsam77's Avatar
if you put it on without rejetting your quad will blow up, so hopefully you aren't near it when it explodes...hahaha, j/k it prolly won't start/run...not to mention if it does and it's lean you'll blow your motor...someone posted a link to an awesome guide that pretty much tells you exactly how to jet a quad...i'll look and see if i can find it
