Grizzly 700 Clunking in rear end ??????
Old Jan 19, 2008 | 05:46 PM
ROCKETKID's Avatar
Default Grizzly 700 Clunking in rear end ??????
I have a 2007 Yamaha Grizzly with 1200 miles on it. Today I started out to ride and I noticed a clicking in my rear end especially when I turn. It sounds like it could be comming from the rear axles or somthing towards the rear wheels. Any idea what this could be? Do I need to replace my rear axle/s?
Any ideas or help would be appreciated. thanks
Old Jan 19, 2008 | 07:48 PM
87 warrior's Avatar
does it do it when your going straight? does it do it when you turn both ways or one way?
Old Jan 19, 2008 | 11:21 PM
ROCKETKID's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 87 warrior
does it do it when your going straight? does it do it when you turn both ways or one way?</end quote></div>
it does it all the time but you can notice it the most when I turn to eather side. Both ways make the same noise.
I was looking in my wheel wells tonight and there is a plastic thing that goes around my whole rim and both right and left one look bent alittle and I almost think when the wheel goes around it might be possibly hitting somwhere???
Old Jan 19, 2008 | 11:31 PM
87 warrior's Avatar
10 to 1 that's your problem. you can put the rear up on a jack stand or something strong enough and spin the wheel to try and see where it is hitting. i was gunna say your bearings are bad but since you found this problem i don't think it's your bearings.
so try and do that.
Old Jan 20, 2008 | 12:11 AM
Mack450's Avatar
i would say your bearings.....my dads 660 goes threw a ton of bearings. the no doubt the reason.....and thats a pretty cheap reason.....when u start talking bout replacing the rear differential your lookin at dough
Old Jan 20, 2008 | 12:22 AM
ROCKETKID's Avatar
so the clunk could be the wheel bearings if not that plastic thing? is there anyway to check the wheel bearings before I bring this to a shop? and are wheel bearings easy to change?
Old Jan 20, 2008 | 02:37 AM
Mack450's Avatar
i did it and i'm 15......i'm sure you could......look it up on the internet....
Old Jan 20, 2008 | 04:14 AM
Williebee's Avatar
ROCKETKID you can loosen the lugnut's on the rear wheels , then jack the rear end off the ground ; then remove the wheel's and shake the axle's to see if there is any play in the axle and axle housing !
And if they are indeed bad it should show sign's of gear oil leaking from around the bearing seal's , as well the side to side and up and down play ; and if there are any sign's of gear oil leaking and the loose play in the axle you will know for sure !.............
Old Jan 21, 2008 | 09:45 PM
grizzhog's Avatar
no worry, same thing happen to my grizz and it was a wheel bearing . hope its the same for you?
Old Jan 22, 2008 | 10:04 AM
stroker101's Avatar
wheel bearings, cv joints or differential. 1 of these 3 items could be the reason. when was the last time the diff was serviced?
