Whats a good oil in the wolverine 450
Old Feb 28, 2008 | 10:43 PM
Hondarider27's Avatar
Default Whats a good oil in the wolverine 450
It may have been mentioned before but what general oil would you recomend in it. Yamalube? I have herd about how you should not using 10w30 with energy conserving on it. Thanks
Old Feb 28, 2008 | 10:52 PM
87 warrior's Avatar
i use yamalube all purpose 10w40 in my warrior. only oil i've ever used. and it works great.
Old Feb 28, 2008 | 11:06 PM
yamahaman07's Avatar
Yamalube is the best.It provides the correct friction modifiers for your clutches.
Old Feb 29, 2008 | 08:11 AM
jarmoore's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: yamahaman07
Yamalube is the best.It provides the correct friction modifiers for your clutches.</end quote></div>
Actually, you need to use Yamalube because it doesn't have friction modifiers. If you use an oil with friction modifiers on the Ultramatic CVT it will start slipping.
Old Feb 29, 2008 | 08:57 AM
Cmarti's Avatar
Friction modifiers (in theory) effect wet clutch operation. I do not know their impact if any on CVT transmissions. The oils in your viscosity will not have the energy conserving designation in the certification star, so it should be a moot point. Changing any oil in the correct viscosity, especially if contaminated by water, dust ,fuel, or break in, may be more important than brand.
Old Feb 29, 2008 | 11:43 PM
Eimajz's Avatar
Sorry to hijack the thread, Is it safe to run AMS OIL synthetic 10w40 in a Wolverine? What does 80w/90 API GL mean?
http://www.kawasakimotorcycle....-oil-mcf_qt_640phx.jpg
Old Feb 29, 2008 | 11:49 PM
87 warrior's Avatar
if you have a wet clutch the synthetic will cause the clutch to slip, so i've herd.
Old Mar 1, 2008 | 11:58 PM
Cmarti's Avatar
I have run synthetics (Mobil One & Rotella T) in wet clutch bikes and quads ( Yamaha & Honda) for years with no problem.
GL is the spec rating for hypoid gear lube in the rear transfer case/final drive. Gear oil is right next to the motor oil at the auto parts store. I believe GL5 is the current high spec. Your quad may call for only GL4. 80/90 is the viscosity of the oil (measured different than motor oil, but let's not get into that)
Good luck
Old Mar 3, 2008 | 11:28 AM
ctateusa1's Avatar
Synthetic will not cause any slipping of the wet clutch unless it has friction modifiers in it. I have experienced it first hand so I know it is the truth.
I run the Yamalube semisynthetic now after about 500 miles(100 after the big bore kit.
Old Mar 7, 2008 | 08:35 PM
wolv98's Avatar
I run ams oil 0w40 yellow cap in my wolv and in my yfz I like it the best.
