Help with Serial/number
Old Apr 7, 2008 | 08:04 PM
pugs47's Avatar
Default Help with Serial/number
I am confused with these numbers.....On the yamaha grizzly does it have a vin number and also a motor serial number. Or is there only one number?
Old Apr 7, 2008 | 08:32 PM
recon99's Avatar
I believe it's the same thing. If I remember correctly the number on the frame will match the number on the engine.
Old Apr 7, 2008 | 09:25 PM
whitford_b's Avatar
what if the motor has been swapped out i have a blaster with a yz 490 motor in it and ive been wondering about the serial numbers
Old Apr 8, 2008 | 12:09 AM
recon99's Avatar
What about it? If the motor is swapped out there's nothing much to say, they're just not going to match. I don't see why it would cause a problem, registration and everything goes by the number stamped on the frame.
Old Apr 8, 2008 | 11:51 AM
myposbussie's Avatar
The engine no. and the chassis no. is not the same no.
I don't know about the VIN but the engine no. and chassis no. is definitly not the same no.
Is there maybe a way I can get my model no. from my enjine or chassis no. ??
Old Apr 8, 2008 | 04:19 PM
pugs47's Avatar
myposbussie.......That's my problem, I cant find the number on the engine, where on the engine did you find your number????
Old Apr 9, 2008 | 12:38 AM
recon99's Avatar
The number stamped on the frame, usually on the bottom left side tube near the engine, is the vin number/serial number.
The serial number on the engine is typically stamped on the top of the engine case underneath the carburetor area.
