finally happened to my Griz
Old Apr 24, 2008 | 04:35 PM
HooPharted's Avatar
Default finally happened to my Griz
this is just how it was when it let go,the part in the hub and the end of the axle,,,the part in the xfer case in the last pic is the part i removed from the axle on the trail and inserted it into the xfer case to keep it clean until i got home
Old Apr 25, 2008 | 10:31 AM
ctateusa1's Avatar
Yhea you broke the cv joint, you didnt mess up the actually hub at all. All you will need is a new complete axle. The ball bearings went in those grooves and that is what allowed the axle to turn and move freely. If you had all the ***** then you might be able to grease and clean the axle and hub reinstall everything with a new boot and c/v boot bands and still use that axle. If there is any damage to either side though it could bind or cause a clicking noise.
ctateusa1's Avatar
ctateusa1's Avatar
Customer Service #1
May 15, 2020 08:46 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
byronman
Sep 6, 2015 06:34 PM
Elkaholic
Sep 6, 2015 02:44 PM
