EPI clutch kit for woly
Old May 8, 2008 | 03:56 PM
justhanginout's Avatar
Default EPI clutch kit for woly
i think catv is in the process of switching over so i guess we'll see
Old May 8, 2008 | 08:21 PM
derrelw's Avatar
My sheave should be back from Hauck and in my hands tomorrow. Ill let you know how it works with the EPI kit and Hauck machining. Should be great!
Old May 9, 2008 | 08:45 AM
so did you get the EPI clutch kit and send them that one instead of the factory clutch.. hmmm
Old May 9, 2008 | 10:19 AM
ctateusa1's Avatar
the epi clutch kit does not replace anything but the springs and rollers, so you can have hauck machine the primary clutch basket and have both(which is what im planning on doing with mine when I get a little more $$ in the bank.)
The epi clutch kit does give you a lot more low end power though.
Old May 9, 2008 | 10:28 AM
  #15
what do you think would be the best way to go about it. do the EPI first then hauk or the other way around
Old May 9, 2008 | 10:32 AM
  #16
pmcc37's Avatar
let us know how it turns out, I'm definately interested
Old May 9, 2008 | 10:38 AM
  #17
ditto
Old May 9, 2008 | 11:08 AM
  #18
Eimajz's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: justhanginout
what do you think would be the best way to go about it. do the EPI first then hauk or the other way around</end quote></div>
I went the Hauck route since I didn't want to lose any top end. As a hauck owner, I will vouch that I can see a difference in bottom end and throttle response time. Depending on how much grease you pack in your rollers it may take a little time to notice the reaction time. Once it is "broke" in you will notice a nice difference.
Old May 9, 2008 | 11:16 AM
  #19
i think i like the idea of doing both. i'm not sure what it would do. if you would get the low end of the EPI and the high end of the hauk should be interesting to see how it pans out
Old May 9, 2008 | 11:22 AM
  #20
Eimajz's Avatar
Yea.. I agree. I'm waiting on Chris's and Derrel's input before I make the jump. I really can't seeing any ill effects, but, I don't want to **** the $$ away if it is just a balancing issue.
