Kodiak VIN Number
Old May 19, 2008 | 10:56 PM
climbinlineman's Avatar
Default Kodiak VIN Number
it does have a skidplate it wouldn't be underneath it would it
Old May 20, 2008 | 12:41 AM
toddmh's Avatar
the vin on my 03 Wolverine was stamped on left frame rail side between the front and rear tire..It was hard to miss..Also I think it is on the motor somewhere..
Old May 20, 2008 | 03:09 PM
Hebs's Avatar
if you're sitting on it, it's on the left hand side behind the front wheel... Even with skids you should still be able to see it... Just follow the frame from the back of the a-arm guard towards the footwell... if you get to the plastics, you've gone too far...
How old does this thing look? Does it have round headlight inserts, or the newer style eye looking ones?
Old May 20, 2008 | 08:55 PM
it has the round headlight and it looks older i won't think it is a 2000 or newer...i was told a 1998, but asked friend about some parts he said it doesn't list a 98 to be 2wd
Old May 22, 2008 | 12:09 AM
  #15
olyguy12's Avatar
Just like everyone said, the VIN is on the left side of the frame. And it's on the side of the tube. I had to lay on the floor to see mine. I had a 97 Kodiak and the number was JY44SHA00TA003***. The Kodiak had a large displacement at 400cc. The Big Bear was a 350 and 2 wheel drive.
Throw a picture out there so we can see what you have.
Old May 22, 2008 | 12:18 AM
  #16
kool i'll get some pics tomorrow and i'll try laying down and look under to see if i can see it
Old Feb 21, 2010 | 08:07 PM
  #17
sbozzetto's Avatar
Thumbs up I've just found my VIN number...
I've just bought an assumed 1996 Kodiak and had the same issue of not finding the VIN. Following this thread advice, I used a cleaning solution along the lower bottom round rail on the left side behind the front tire. I finally found the light imprint with a flashlight. It was farther back, directly under the foot-gear shifter and pull-start mechanism. However, I'm not positive on a couple of faint digits due to the frame paint job it received at some point.
Old Feb 22, 2010 | 08:13 AM
  #18
sdride's Avatar
It's in the location that everyone stated but it's not very deep si if you have any dirt or rust it may be hard to see. I had a hard time trying to get a clear rub when i went to register mine
Old Oct 10, 2023 | 11:25 PM
  #19
jhunt1988's Avatar
Originally Posted by climbinlineman
i have a kodiak that was givin to me and i don't know the year to get it worked on....does any1 know where the VIN# is located on this quad? if u know of a website that will have a picture where its located at? i was told it is a 400 2x4...person said they think its a 98 but when i went to get a part they place said they don't show a listing for a 2x4 400 for a 98. he told me to get the VIN# and he could find out....any1 got a clue where its at cause i don't...lol
This is where and what the serial number looks like.
if this helps any.
Old Oct 10, 2023 | 11:33 PM
  #20
jhunt1988's Avatar
If you seating on the atv and look on the left side it will be right behind the front tire. Standing on the left side look between the right side of the tire and the fender it will be straight back on the frame.
