Wolverine starting problem
Old Jun 11, 2008 | 07:59 AM
Randallk00's Avatar
Default Wolverine starting problem
Ok my Wolerine is having some electrical problems that I cant figure out. It would be real weak when starting like it wanted to die like the battery was weak but sometimes it would start. Then even as you were riding it would get so weak that it wouldn't start it would just click at the starter relay. SO I replaced the relay which did next to nothing. SO then I replaced the battery which did nothing. SO now I'm a hundred bucks in the whole and the only thing I got out of the deal was more frustration. So does anyone know what the next logical step is. Thanks in advance for any help.
Old Jun 11, 2008 | 02:01 PM
brent1's Avatar
I would take off the positive battery post and see if it still runs. If it dies the stator or rectafier could be bad you can check the stator with a ohm,s meter and the retafier too. if you have a manual for the bike it should tell you the ohms you need to look for. Now for replacing the starter selinoid the starter siloniod will click if it has low voltage to it if you already replaced it you probably didn't need it. Because you put a new battery in it the only thing else would be the stator or rectifier.
suzuki230
Jul 8, 2016 10:03 AM
Nelson
Jun 20, 2015 01:59 PM
1000gade
May 27, 2015 12:37 PM
ragewraps
May 27, 2015 08:07 AM
holmbergm97
May 27, 2015 07:23 AM
