won't start
Old Jul 7, 2008 | 08:19 PM
kbelttx's Avatar
Default won't start
I have a 98 big bear. two days ago i noticed fule running out of the carb drain hose. now it is a bear to start. i can't stop the fuel from coming out. what do i do?
Old Jul 7, 2008 | 08:35 PM
grizzhog's Avatar
Default won't start
Fist of all is it the over flow drain hole or the bottom drain hole underneath the carb ?
If it is the flow drain, the floats in the bottom of the Carb could be the problem. If it's the drain hole at the bottom of the Carb then the screw as a rubber washer, it could need replacing ....
GO BIG OR GO HOME
Old Jul 8, 2008 | 10:32 AM
kbelttx's Avatar
Default won't start
Anywhee I can go online for a manual on the carb? With Picture/diagrams?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
