2007 or 2008
Old Jul 16, 2008 | 09:30 AM
TLC's Avatar
TLC
Default 2007 or 2008
<div class="FTQUOTE"><begin quote>So what are the differences between an 07 vs 08 model? </end quote></div>
The year they were built..
Old Jul 16, 2008 | 09:36 AM
IronBear's Avatar
PF Powersports LLC
<div class="FTQUOTE"><begin quote>Originally posted by: TLC
The year they were built..</end quote></div>
Thank you for pointing out the obvious
Old Jul 16, 2008 | 10:18 AM
Krait's Avatar
They updated the airbox lid to seal a bit better. Can't think of anything else they changed offhand.
-Krait
Old Jul 16, 2008 | 10:27 AM
IronBear's Avatar
PF Powersports LLC
Thank you Krait..[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 16, 2008 | 10:46 AM
  #15
immerume2's Avatar
I am suprised to see everyone hating on the extended warranties. I had my quad for about 8 months and then all of a sudden backing it off a trailer with ramps that was only about 1.5 feet off the ground the rear brake assembly busted and ruined the entire rear brake assembly. Took it in and it ended up being that they replaced the brake assembly the line the rim that the assembly bent when it came off and the rear axle.
Rear axle ... dunno the cost
brake assembly ... dunno the cost
rim.... dunno the cost
warranty replacement and not having to know the cost.... almost priceless.
Old Jul 16, 2008 | 12:55 PM
  #16
Snortwheeze's Avatar
just a question is the power steering on all the time or can you turn it on or off? as for the warrenty it depends on the way you treat the machine if you will baby it go with 6 months. if you will beat the crap out of it go with the 3 years because i am sure you have to spend over 600 on fixing it then. or if you have friends that are crazy go with the 3 year. I say that becuase we went out ice fishin with a bunch of buddies, there was 3 quads. with 6 people. none of them broke but one was close to rolling it over and it wasnt even his quad after that all the keys came out and into the pockets of the owners. so even though you trust them. keep a carefull eye on your friends.
Old Jul 16, 2008 | 01:13 PM
  #17
Krait's Avatar
The power steering is 'on' all the time, it works more when you are driving slow. The faster you go, the less it helps, as at higher speeds steering becomes easier. I don't know of any vehicle with power steering that allows you to 'turn it off'. Unless you turn the vehicle off.
Could be wrong tho.
-Krait
Old Jul 16, 2008 | 04:15 PM
  #18
that makes sense. i didnt now if it was going to be toooooo easy to turn while going really fast and end up over steering and have a bad accident
Old Jul 16, 2008 | 04:31 PM
  #19
Krait's Avatar
Well honestly I have heard of some ppl finding the steering too twitchy at high speed, so maybe its still a little too easy...not sure tho some ppl love it and have no problems going fast with it. I guess it just takes a bit of getting used to.
Try it yourself and see if its a big deal...I would think it might be a little twitchy, some ppl can adjust some can't. I know DesertViper rides his like a sport quad, so it can't be that bad...
-Krait
Old Jul 16, 2008 | 04:34 PM
  #20
Hebs's Avatar
they also added some heat shield straps to the shield on the exhaust can... That's all I can really think of...
Scooter's Shop
23
Oct 22, 2015 07:04 PM
35dodge
Sep 29, 2015 09:40 AM
rgjackson
Sep 23, 2015 01:53 PM
Sep 23, 2015 06:23 AM
braap123
Sep 7, 2015 12:58 PM
