YFM 80 Help
Old Aug 26, 2008 | 07:10 PM
jwalk1818's Avatar
Default YFM 80 Help
Well my dads friend has bought a 4 wheeler over the other day wanted me to look at it.....wasnt sure exactly what it was! It sais shaft driven on the side and YAMAHA so I did reasearch and Im assuming its a badger 80? I cleaned the carb it was all gummed up, it has a fresh battery, and spark plug and does have fire and compression but will not hit a lick..! Can someone help me with some tech support?
Old Aug 26, 2008 | 08:53 PM
4WRIDER's Avatar
Default YFM 80 Help
I am dealing with the same ATV & problem. Have you tried to push start it? Mine will go, but only iff you push it. I will watch your post to see if WE can get it resolved
Old Aug 27, 2008 | 02:13 PM
100's Avatar
100
Default YFM 80 Help
check the valves we have a raptor 80 which i think whould be the same motor and it had the same problem the intake valve was tight so i adjusted it and it started right up.
Old Jun 14, 2011 | 10:36 PM
kablake's Avatar
Question yfm badger 80
i have one also when its cold its hard to start , i read something about the intake valve on the carb. i read to open it more and i would but i dont know what one it is
Old Jun 15, 2011 | 06:31 AM
Terrellster's Avatar
You'll need to buy the manual - Online they're cheap, downloadable ones. Available through Ebay. It's the valve timing that's off, typically.
Old Jun 15, 2011 | 11:45 AM
snow racer's Avatar
Valves!! Thease are very finkey when it comes to valves.
Old Jun 15, 2011 | 07:31 PM
kablake's Avatar
would you know how to adjust the valves
Old Jun 15, 2011 | 07:47 PM
snow racer's Avatar
i dont know the specs sorry. any yama tech shuld know it off the top of there head.
Old Jun 16, 2011 | 08:53 PM
beyondupnorth's Avatar
The loose side of the spec is .010 intake and .012 exh with the engine cold.
send me a email and I'll send you the Yami 80 manual
ken at skidsteer.ca
Old Jun 16, 2011 | 09:08 PM
snow racer's Avatar
Can you email me @ moto4man@gmail.com
