660 Raptor Carbs
Old Sep 7, 2008 | 11:04 PM
Raptorboy171's Avatar
Default 660 Raptor Carbs
I need to rejet my 2003 660 raptor, what is the easiest way to get the jets changed and how do you do it?
Old Sep 8, 2008 | 12:46 AM
Raptor450's Avatar
Pull the carbs off, which will require the front fenders to be removed (I think). You don't have to comepletely remove them, just get them loose so you can get the bottom bowls off. Then pull the carb bowls off. Then just remove the jets and replace with the new ones. Then you have to replace the springs and set the needle position or some kits come with new needles. When I did the Curtis Sparks jet kit (Dynojet kit with pilot jets added) on mine, it came with step-by-step instructions. You could probably go to Dynojet's, Sparks Racing's or some other website and get detailed instructions.
Also keep in mind the left carb has a smaller main jet than the right, so don't let that mess you up. Even when you rejet, the left jet will still be smaller.
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
