carb tuning
Old Sep 26, 2008 | 08:35 PM
skj283's Avatar
Default carb tuning
hello, just put a gytr exhaust on my wolverine 450. bumped the jet from a 131.3 to a 135 and the plug shows it is plenty rich. it seems to run fine but was curious where the needle affects the most. i am guessing it in basically the transition circuit from say 1/4 throttle to wide open. would this mostly help with throttle response? just curious what you all had to say. thanks
Old Sep 27, 2008 | 12:17 AM
hotblooded's Avatar
Default carb tuning
The needle position is a way to lean or richen it out. By dropping the clip you will richen it by raising it of course you will lean it out.
Old Sep 27, 2008 | 01:11 AM
skj283's Avatar
Default carb tuning
will it richen it under wot conditions. i was under the assumtion that at wot the needle was out of the equation and fuel flow was determined by the main jet orifice size.
Old Sep 27, 2008 | 01:34 AM
hotblooded's Avatar
Default carb tuning
This will affect just off idle to the high end. The reason is the nozzle (where the main jet screws into) has 8 little holes in the side. The faster you bring the needle up the more rich it will be, so if the clip is dropped in a lower notch it will lift needle faster and more gas will get in. I hope I made sense, sometimes I confuse my self
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
black_thunder
Jul 26, 2015 09:23 PM
Aitch
Jul 21, 2015 09:40 PM
maxjung
Jul 13, 2015 05:11 PM
