2004 yamaha 350 bruin
will start and idle fine , after it warms up and you give it throttle to go at about five mph it starts to misfire, have replaced sparkplug, cleaned carb with cleaner cant be the gas have two other four wheelers that run fine all where gassed up with same fuel at same time, was thinking fuel filter? but dont see one, any ideas greatly appreciated tia irtech
If this is the same as the raptor, it's a problem with your parking brake. Follow the Wires coming out of the parking brake, and you will get to a white connector. Disconnect. and try to rev it up. That should solve your problem.
