YFZ NOT STARTING
Old Nov 2, 2008 | 07:58 PM
stormnorm's Avatar
Default YFZ NOT STARTING
My 04 YFZ 450 won't start after sitting for a few weeks without running. The oil from the oil tank drains slowly into the engine. Oil level barely showing on the stick but after finally starting it (by towing it behind my car) the level rises to normal. My buddy's Harley won't start either when all the oil has drained into the engine. Apparently this is a common problem with old Harleys. Could the oil in there keep the engine form starting in the YFZ? Has anyone noticed the oil draining like this?? I will be changing the sparker in the next coupla days...will see if that helps.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
