96 Warrior Carb Question
Old Nov 20, 2008 | 06:12 PM
fastang's Avatar
Default 96 Warrior Carb Question
I just put a used carb on my 1996 Yamaha Warrior. It will only idle when the idle screw is all the way. Also it sputters and blows a little black smoke until I have it about half throttle.
Any suggestions?
Thanks!
Old Nov 20, 2008 | 06:31 PM
91Warrior357's Avatar
it seems like its running real rich, youll prolly have to rejet the carb, is it a warrior carb?
Old Nov 20, 2008 | 06:33 PM
fastang's Avatar
Yeah, I got it off ebay.
Old Nov 20, 2008 | 06:46 PM
does it actually drive ok? id take it apart and try to get it jetted correctly. for all you know the person who had it could have been at a high elevation and had aftermarket pipes or something
Old Nov 20, 2008 | 06:55 PM
fastang's Avatar
Yeah, once I get it to half throttle it seems to run great. I will order a factory rebuild kit for it and see if that fixes it.
Old Nov 20, 2008 | 06:58 PM
you try adjusting your fuel screw in? your pilot jet is prolly too big it seems like, if you order a jet kit it will come with directions and all the jets you need to get it dialed in correctly.
Old Nov 20, 2008 | 06:59 PM
fastang's Avatar
Thanks man, I appreciate your help. I will play with the fuel screw.
Old Nov 20, 2008 | 08:41 PM
fastang's Avatar
One more question. On the carb there are three places for tubes. On the bottom for drainage, the fuel inlet, and one more. It isn't connected to anything. Is that correct or should it be hooked to something. Please excuse my ignorance.
Old Nov 21, 2008 | 09:44 AM
Politically Incorrect's Avatar
Yep Sounds to me like somethings up with your pilot jet, either it's stopped up or it's too big. But most people never replace the pilot jet with aftermarket pipes or mods. Usually the main jet is what needs to be replaced with mods.
Old Nov 21, 2008 | 06:46 PM
<div class="FTQUOTE"><begin quote>Originally posted by: fastang
One more question. On the carb there are three places for tubes. On the bottom for drainage, the fuel inlet, and one more. It isn't connected to anything. Is that correct or should it be hooked to something. Please excuse my ignorance.</end quote></div>
that other inlet hole is just a vent and there should be a hose on it hanging out near your airbox
