Dynojet jetting
Old Feb 7, 2009 | 09:56 AM
ftwflh's Avatar
Default Dynojet jetting
I took the White Bros pipe off the Warrior and couldnt find the instructions on what jetting should be with stock pipe w/K&N filter.I went from a 138 to a 130.Have run it enough to check the plug.
Any one have the Dynojet recomendations
Old Feb 7, 2009 | 05:01 PM
WAS_P1FOXRIDER's Avatar
the DynoJet web site says if you are running the stock exhaust use the DJ134 below 3000 feet, DJ130 from 3000 to 6000 feet and DJ126 above 6000 feet. this is for a stock air box set up also
Old Feb 7, 2009 | 05:19 PM
ftwflh's Avatar
Thanks I need to change that out
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
