Ran w/o oil
Old Feb 17, 2009 | 02:09 PM
Swerve's Avatar
Default Ran w/o oil
I found a warrior engine for cheap that was ran w/o oil. The shop says the valves and cam are destroyed but what are the chances that the bottom end is still ok? Seems if the system was starved for oil that the top end would be the first to go but can the bearings in the bottom end run very long w/o oil?
Old Feb 17, 2009 | 02:17 PM
maddog56's Avatar
Default Ran w/o oil
Depends on how long it was ran, if they shut it off when the top end started to freeze up then the bottom end might be ok, but if pooped out a half mile down the road and they drive it all the way home you're going to be replacing a lot of parts.
Old Feb 17, 2009 | 02:31 PM
Swerve's Avatar
Default Ran w/o oil
Yea thats kinda what I figured and I don't have a clue how long this thing was ran.
