Oil Change Raptor
Old Feb 12, 2001 | 10:37 AM
Luckydog's Avatar
I was changing the oil in the raptor and followed all the instructions in the manual to a tee. I replaced the oil filter and put the two drain plugs back in and began to re-fill. The manual says you will need to put in about 2.07 US Qt. but I hadn't even gotten 2 qt in and it was full. I filled it where you check the oil. Did I do something wrong? Do you have to start it to get the oil to the Crank Case. Thanks.
Old Feb 12, 2001 | 10:40 AM
xtreme165's Avatar
Luckydog, Ya start the quad then shut it off and then put the rest of your oil in.
Old Feb 12, 2001 | 10:44 AM
Luckydog's Avatar
Thanks, I was afraid I was doing something wrong by starting it.
Old Feb 12, 2001 | 03:33 PM
No2StrokeBs's Avatar
When you drain the oil you drain it out of everything, Holding tank, crankcase, filter and oil lines. When you go to fill it only the holding tank gets filled, so you must cycle the engine to allow the oil to flow to all parts of the engine.
Kaleb_00
Jun 1, 2016 09:15 AM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
