Warrior Clutch issues
Old Apr 2, 2009 | 03:42 PM
Skatike27's Avatar
Post Warrior Clutch issues
I have a 1999 yamaha warrior. When I first start it and take off, the clutch grabs right away, spinning the tires. But after 5 min of riding, if I stop try and take off again, the clutch just slips and then eventually grab. Im assuming I need a new clutch or springs, but am looking for someone with a little more experience on the subject.
Old Apr 2, 2009 | 08:53 PM
JLsparky7's Avatar
What kinda tranny fliud are you running? Might be the wrong weight.
Old Apr 2, 2009 | 09:31 PM
beefy46172's Avatar
Loves To Ride!
Warrior's don't have tranny fluid. They just take motorcycle specific motor oil for everything. First thing is are you running wet-clutch specific oil? You cannot just use regular automotive motor oil because the additives will cause the clutches to slip--but if that has been the case your clutches are now junk and need replaced anyway.
If I were you I would just buy a new set of clutches and HD springs and be sure to use wet clutch safe (motorcycle) oil to fill up the engine with--as long as you are sure you cannot adjust it to work.
Old Apr 2, 2009 | 10:50 PM
JLsparky7's Avatar
I know, force of habbit from talking banshee and blaster all day long.
The new clutch is prolly a good idea. Make sure you soak the clutch plates in the oil before you install them
Old Apr 3, 2009 | 09:44 AM
Skatike27's Avatar
I was running supertech 10-30. Im assuming not the correct oil, from what was said above.
Old Apr 3, 2009 | 11:09 AM
JLsparky7's Avatar
Im not too familiar with klotz, maybe someone else can chime in. I thought it was just tranny fluid not motor oil.
Old Apr 3, 2009 | 11:51 AM
beefy46172's Avatar
Loves To Ride!
Supertech is Wal-Mart full synthetic. You could try to drain that oil and use a wet clutch safe motor oil--the easiest to find is Valvoline Motorcycle oil, they sell it at Advance and Auto Zone; or go to your local motorcycle/ATV dealer and get a wet clutch safe motor oil from there. Problem is normally once clutch plates get soaked in the wrong oil for a while they are normally bound to slip forever.
Like I mentioned earlier, you would really be best to go ahead and replace the clutch and be sure to use a motorcycle specific wet clutch safe oil.
Warrior's do not have tranny fluid, period. The entire engine and transmission is lubricated by motor oil.
Old Apr 3, 2009 | 12:46 PM
JLsparky7's Avatar
And clutch.
Old Feb 12, 2010 | 06:44 PM
djdeyo17's Avatar
i have a 1997 warrior and i am in the middle of changing my clutch i was wondering if anyone would know the specs on the bolts that go through the springs
Old Jul 16, 2011 | 09:18 PM
Yamaha Warrior 350's Avatar
Default rattle in clutch
i just bught a 2001 yamaha warrior 350. it has a rattle noise it sounds like around the clutch box. it doesnt sound like a knock in the motor just as if somthing is loose. it doesnt seem to affect riding can anyone one help????
