turning a raptor
Old Apr 7, 2009 | 08:22 PM
wheily's Avatar
Default turning a raptor
wasent sure were to post this but here goes i have a 05 raptor 350 and im havin trouble geting it to turn slide threw a corner .it goes strait i tried hitenn the rear brakes and then gassin it went straight,lifted out of throttle turned and stabed the throttle lifted front tires and went straight . what am i doing rong i used to ride a zx400 and it would slide no brob threw a corner. o and iam running hole shots on the back and used sand sharks whin went to pismo did the same actually worse with the paddles.
Old Apr 7, 2009 | 08:43 PM
Sidewinder500's Avatar
sounds like too much traction, try leaning farther forward and to the inside of the corner, then when you rev it out push with your feet on the pegs to the back and outside of the corner. If you are continuing to go straight it means your front tires arent gettin the traction to turn it, more weight forward riding thru the corners should correct the issue.
Old Apr 8, 2009 | 09:19 AM
wheily's Avatar
thanks ill give that a try.
Old Apr 8, 2009 | 11:02 AM
beefy46172's Avatar
Loves To Ride!
Either you need new front tires or....go faster
Old Apr 8, 2009 | 04:43 PM
91Warrior357's Avatar
yea if your front tires arent sliding then its just a matter of using your body weight to get the bike sliding where you want, lean to inside of turns and move your butt off the seat and gas on it.
Firefighter400
Oct 8, 2022 06:38 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
