2004 big Bear
Old May 11, 2009 | 03:33 PM
yamaha rookie's Avatar
Default 2004 big Bear
I have a 2004 400 that has not been run alot. Got it running good but only with the choke wide open.
Also seems to drain gas through the over flow at bottom of carb. Any easy fix suggestions?
Old May 11, 2009 | 04:54 PM
woodsidewarrior's Avatar
Sounds like you have a dirty carb. take the bottom bowl off and and remove the jets and clean them out same with the valve on the float
Old May 11, 2009 | 07:34 PM
Question thanks, so next step
Was looking at the carberator and wondering how much stuff has to come off to get the carb off so I can clean it? Seems to have two halves, and several vent tubes.
exmotocrosser
Sep 13, 2019 06:12 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
jbrewster94
Sep 23, 2015 04:16 PM
