gas in oil
Old Aug 18, 2009 | 07:13 PM
jleo's Avatar
Default gas in oil
My 03 Big Bear was starting and running fine at idle, but when I pushed the gas it would stall instead of rev.
I noticed gas leaking out of an overflow tube coming from the carburator. This tube has a screw where it goes into the carburator, I figured the screw might be loose and when I hit the gas it is leaking out of the tube instead of going where it needs to go. So I tightened the screw and then when I tried to start the quad it would crank but not start. I unscrewed the oil dipstick to check the oil and a gas/oil mixture came gushing out of where the oil dipstick screws in.
I dont know how gas got into the oil but it seems to me like it could be a serious problem.
Does anyone have any ideas, what the problem could be?
Old Aug 19, 2009 | 01:23 AM
Doctorturbo's Avatar
GOT BOOST!
Stuck carb float. Pull the carb, fix the needle and seat problem, change the oil and go have fun.
