Does a dent in a pipe affect anything?
Old Feb 22, 2001 | 12:14 AM
H300F's Avatar
Will a small dent in Toomey banshee pipes, one dent in one pipe not both, affect anything? like perfomance?
i am considering buying a set but one of them has a dent, but he said it doesnt affect anything and he raced like that for 2 seasons??
help me out
Old Feb 22, 2001 | 02:17 AM
AdrenalinFreak's Avatar
I dont see it affecting anything to much. It might make a bit of a difference depending upon the size of dent. If there is a hole it will definatly make a difference.
Old Feb 22, 2001 | 11:03 AM
sik_banshee's Avatar
You can get the dent out by filling the pipe with water, plugging the ends and putting it in the freezer.
Old Feb 22, 2001 | 01:03 PM
RobCulp's Avatar
A small dent won't really hurt anything on a 2-stroke expansion chamber.
Old Feb 22, 2001 | 01:28 PM
rennym's Avatar
Yes, dents do make a difference. The pipe chamber is specially designed to reflect gases back into the piston chamber. If you dent the chamber, it will effect the efficiency of the pipe. If they are small, then don't worry too much about it.
I have seen a dent remover, which uses compressed air. You put two specially made caps on either end, pump it up to 50-80 psi, and gently heat the dent. It will come out. In a rare occasion it will rip, but it largely depends on the dent.
I would be cautious of the water method, as freezing water will break almost anything (rocks, frost, etc.) and it is tough to monitor or control. A good shop should have the dent remover and it shouldn't cost too much to do.
RM
Old Feb 22, 2001 | 04:15 PM
H300F's Avatar
hey i will go with them and try them out, and check into removing the dent. if it is up in price, i will try the freezing method... thanks for all your help.
bmxatv10
Oct 14, 2022 06:23 PM
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
greg86hd
Sep 16, 2015 12:32 AM
