96 yamaha blaster no spark any suggettions?
#15
thanks again for everyones help. I ended up takin it to a shop they said there was a bad wire in a box and not all the saftey switches were disconnected. Anyways it was running pretty good for bout an hour or so then it died. i can get it started sometimes but sputters then backfires and dies. Does anybody have an idea on whats happening now?
#17
It has new gas, plug, and wire. The reeds look good, air filter is clean and i put a carb off a running blaster still no luck. Can i check the compression without a special tool? If you hold your thumb over the plug hole and kick it will blow your thumb off the motor. Thanks for the help got anymore suggestions?
#18
What does the condition of the spark look, should be bright blue or purple and consistant, is the float bowl full of fuel? you can ck-that by opening the bowl drain screw, infact if spark and compression is good then it's probably a fuel delivery problem. I don't recommend this often...remove the air filter and spray choke cleaner into the air box, (use discreation) and if it runs for a moment than it's probably a carb. issue. don't use starting fluid (to volitoll), and don't use much because it will wipe the cylinder clean of oil. you should use a compression gauge to know exactly how much you have. most engines require at least 70 to 80psi to start. If she ran for awhile then died, i wouldn't worry about coil and stator, i would think that would be more of a "no start, no spark" condition. hope i was some help, it is frustrating but it can also be a fun puzzle...
#19
Funny thing even though the spark was blue. When i took it to a buddys house to have him look at it all of a sudden i couldnt get spark. The brand new stator burned out i geuss. I put an old one on it and have about three hours of ride time on it with no problems. Thanks for the help
Frisky2050
Apr 9, 2020 11:19 AM
joeyupton
Jul 14, 2015 11:51 AM
Jul 7, 2015 11:00 PM
