Just Picked up a new WARRIOR
Old Nov 30, 2009 | 10:29 PM
Lamont21's Avatar
Question Just Picked up a new WARRIOR
I just got a 2000 yamaha warrior 350.Are the good and reliable atvs?It drives and runs real good and is very fast.I wanted to know what metanance i should do because it has not had anything done to it in six months except cleaned the air filter.
Old Nov 30, 2009 | 10:32 PM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
I would change the oil, make sure you are only using motorcycle oil though, something with wet clutch protection, oil up the chain, other than that you should be fine, maybe change the spark plug if it hasn't been done in a while.
Old Nov 30, 2009 | 10:39 PM
Lamont21's Avatar
Thanks for the reply,why is my clutch hard to pull in
Old Nov 30, 2009 | 11:24 PM
xcitmt's Avatar
A good warrior is hard to kill.. take care of it and it will take care of you. oil.. plugs.. chain.. a carb clean.. and it will love you long time. remember the siixth gear... have a buddy that has a 250ex and forgets the 6th... lol... they love to play hard.
Old Dec 1, 2009 | 02:16 AM
carlobee's Avatar
that's a pretty good one. nice choice.
Old Dec 1, 2009 | 10:40 AM
warrior-435's Avatar
I have 20002 warrior also make sure keep oil changed frequently warrior are bad about rod bearings other than that there tough and reliable thats why there practicaly unchanged since 1987 when they were introduced and like posted earlier make sure use motorcycle oil or you won't have a clutch long I use honda oil in mine i like it better than yamalube just my preference 2nd owner had since 2001 no bearing problems yet mainly stator and starter clutch
Old Dec 3, 2009 | 08:27 AM
Swerve's Avatar
Warrior clutches are just that way. They are all hard to pull in compared to other clutches.
Old Dec 6, 2009 | 12:23 PM
yamahawarrior1986's Avatar
i have 2 warriors and they are great 4wheelers. on one of them i have an fmf exhaust, reduced in size front sprocket, uni air filter, dynojet jet kit, and a powerbomb header. it is super fast. it will go 75mph. they are great trail riding atvs. as far as wat you should do, i would definitely change the oil and spark plug and clean the oil filter and air filter.
Old Dec 6, 2009 | 12:45 PM
Lamont21's Avatar
How do I clean the oil filter?do I clean it with soap and water
Old Dec 6, 2009 | 01:20 PM
clean it with gas
