Grizzly jetting question
Old Feb 27, 2001 | 03:45 PM
yam8's Avatar
I have a 2000 grizz, and it has a 40mm carb on it, i do long trips and want to get better gas mileage. My buddy has a 98 big bear with a 2.5 gallon tank and he goes the same distance I go on a 5 gallon tank. If i drop 2 jets to bring it to 38mm will it hurt anything, how much top end power would i loose, and how much more better will the gas mileage get. I know i'm driving a 600 opposed to a 350 but i'd rather get good gas mileage than be able to beet everyone out there.
I also do not want to damage anything either.
Any educated responses would be great.
Thanks
Old Feb 28, 2001 | 02:08 AM
Bushbunny's Avatar
Howdy...going down two jet sizes will make your griz run lean...hard to say if you consider burned valves and a piston as not a bad thing...I would look at gearing first or different clutch weights...I'm not sure if you can buy different crown and pinion gears for your diffs...talk to your local parts guy at the Yamaha dealership and see if anything is available...hope that helps...
BB
Old Apr 17, 2006 | 12:05 AM
grizrock's Avatar
Default Grizzly jetting question
I have a 04 grizzly will putting a K+N air filter with the motionpro adapter/ require me to rejet to a larger jet
Old Apr 17, 2006 | 12:06 AM
grizrock's Avatar
I have a 04 grizzly will putting a K+N air filter with a motionpro adapter require me to re jet to a larger jet size ?
Cole Hadden
Jun 15, 2025 09:05 AM
RedRancher
Oct 15, 2020 01:45 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
Jul 28, 2015 12:12 PM
toonces
Jul 11, 2015 12:01 PM
