bear tracker
Old Mar 18, 2010 | 09:34 PM
dbking321's Avatar
Default bear tracker
I just bought a yamaha bear tracker and I found a set of used grizzly 660 tires and wheels. The rims have the same bolt pattern as the one that they are now, but the tires are 25" instead of 22". Will they fit or will they rub?
Old Mar 18, 2010 | 10:11 PM
TLC's Avatar
TLC
I had 25" tire on my old 86 250 Yamaha Moto 4 and they worked. 10" wide backs and 8" fronts .
Old Mar 19, 2010 | 06:17 AM
dbking321's Avatar
did you have any rubbing problems
Old Mar 19, 2010 | 09:43 AM
TLC's Avatar
TLC
No I did not,but I know the Bear tracker is the Moto4 replacement and I,m not sure if your frame and suspension would be different. 25" tire are not that big.
How wide are you new tires vs your old tires? As for hight ,remember you only need a extra 1" clearance if the tire is 2" taller.
Old Mar 19, 2010 | 09:56 PM
dbking321's Avatar
ok thanks i might have to hold off on getting bigger tires until i can manage to get the tires and the quad together.But thats for the help
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
