%^#@&** Tri-Z 250 Killing Sparkplugs
Old May 15, 2010 | 08:30 PM
danatack's Avatar
Thumbs up
Originally Posted by danatack
over twenty years ago i remember the same thing happend on my 85' tri-z, it ended up being the coil, is was 13 then so bare with me. i remember it eating pluggs, i had small town sponsorship through our yamaha shop and the mechanic told me he replaced the coil... wow long time ago. any way they say to test the cdi with a known good component rule. that always told me they don't know how to test one lol. i wouldn't worry about a book just yet. ck-to make sure stator, coil, etc. have good component grounds, the stator sends a pulse signal to the cdi, you would notice a wire coming out of the stator pulsing your test light dimly but steady. current goes to the (pre-mapped) cdi. each cdi has been designed with a spark curve, and rev. limit for that specific machine, then current goes to the coil were the coil is just one big resistor, or capacitor(gathers and holds an electric charge), generates a healthy spark20 to 60kv exp. then goes through the hi-tension lead to the spark plug to ground.
i hope that was a little help, i'm looking for my old tri-z manual if you need specific values... nice ride
Old May 15, 2010 | 08:48 PM
Raptor450's Avatar
over twenty years ago i remember the same thing happend on my 85' tri-z, it ended up being the coil, i was 13 then so bare with me.
Wow! 13 on a Tri-Z? That's scary! I was worried about the grounding issue, because I had just put the engine back in the frame after a rebuild, but I had already started the engine and ran it for a few minutes. A few days later I went out and tried to start it again and that's when this problem came up. I haven't even ridden it since I rebuilt the engine.
Thanks for all the replies, I replaced the ignition coil tonight and it seems to be working properly. I'll see if it will run tomorrow, I'm dying to try to start it but it's getting late and I don't want to wake the neighbors!
Old May 17, 2010 | 07:20 PM
Raptor450's Avatar
It must have been the ignition coil, it's running again. The sparkplugs that I thought were dead now work with the new coil, so I guess the old coil was giving out instead of the plugs going bad.
Old May 17, 2010 | 10:13 PM
91Warrior357's Avatar
yea cool, that makes sense a weak spark can trash plugs since the fuel isnt being burned right i guess.
Old May 21, 2010 | 11:17 PM
  #15
danatack's Avatar
right on, happy trails...
Old May 31, 2010 | 11:40 AM
  #16
Unknownquad's Avatar
Default Cdi unit.
Raptor 450 if you still have that old cdi unit and it works, i can take it off your hands. Same thing happend to me so i took it off and it was run over. Nightmare!!! let me know, Thanks
Old May 31, 2010 | 08:49 PM
  #17
Raptor450's Avatar
That sucks! Gotta be careful with those old discontinued parts!
It does work, but I'd rather keep it for a spare, and I plan to build another Tri-Z one day. If you REALLY need it, I'll let it go, but there are a ton of them for sale on Ebay. I got mine for $50. Most were going for $100.
Heres a couple of pics of us at the dragstrip last weekend
Attached Thumbnails %^#@&** Tri-Z 250 Killing Sparkplugs-2.jpg   %^#@&** Tri-Z 250 Killing Sparkplugs-1.jpg   %^#@&** Tri-Z 250 Killing Sparkplugs-8.jpg   %^#@&** Tri-Z 250 Killing Sparkplugs-7.jpg   %^#@&** Tri-Z 250 Killing Sparkplugs-4.jpg
Old Jun 1, 2010 | 03:25 AM
  #18
Tell me about it. Ok then well I will have a fish round and see what I can come up with. Also I have a cd manual for the tri 250 z if it would be any help!
EIF
Apr 20, 2017 07:15 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Halffast17
Sep 11, 2015 02:30 PM
alzgarvin
Sep 11, 2015 08:53 AM
Albertaboyy
Sep 9, 2015 09:51 AM
