CV axle removal
OK this is my first post, be gentle.
I have a 2008 Kodiak 450 with around 2500kms on it.
late last Fall i noticed a slight leak in the left rear axle at the diff.
I used the bike for a club ride last month and noticed that the diff was very hot and leak was getting a little worse.
After the ride i checked the oil level and it was good.
I had one brake cable that tended to freeze so i chocked it up to that,
so i backed off the brake adjustment until i could check it out.
Today i serviced the cable, removed the moisture and pumped oil through it, then adjusted the brakes.
I also changed the diff oil, cleaned up leaking residue, then went on a 20 minute ride, and then checked for leak and exsesive heat.
No leaks or heat, i am hoping the cable sticking was the problem with brakes dragging causing the over heating of the oil thus causing the minor leak.
Has anyone removed a CV axle on a late model Yamaha's,
i assume they are the same procedure?
I tried to just pull it out of diff after disconnecting it at the hub
but no go.
I have a new seal just incase i have to change old one.
After looking at the rear diff setup , i cant see how the diff would have enough room to get out of the small confined space at the back frame.
Hopfully there is an easy way for this?
but no go.
