yamaha raptor leaking fuel help!!
Old Apr 2, 2011 | 02:02 PM
cbaumy's Avatar
Default yamaha raptor leaking fuel help!!
I finally got my raptor's carb cleaned out and started after sitting for two years. It is running fine and idles, however even after I shut it down and turn the fuel off it is leaking out of drain hose from bottom of carb. The screw for the drain is tight and throttle is not stuck open. Any ideas why this is happening?
Old Apr 2, 2011 | 06:13 PM
Kerbbirds's Avatar
the needle and seat in the carb need replaced or ther is dirt, rust unnder it, after you replace it keep Seafoam in the gas 3 or 4 times a year and turn the gas off when not in use
Firefighter400
Oct 8, 2022 06:38 PM
black_thunder
Jul 12, 2015 11:04 PM
Unzzy66
Jul 11, 2015 10:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
