Need info on drilling out clutch weights on Wolverine
Old Mar 11, 2001 | 06:19 PM
Labs's Avatar
Someone posted on a thread awhile ago about a modified Wolverine that had the clutch weights drilled to change the stall speed. Could someone post that link again or web address agian.
Thanks
Labs
00Wolverine
Old Mar 11, 2001 | 06:36 PM
thenewfiebullet's Avatar
I saw something about that on the highlifter forum about a month ago.
Try doing a search about clutch weights on this forum and you'll find anything that was posted about it over the past few years.
Old Mar 11, 2001 | 07:16 PM
Labs's Avatar
Hey Thanks alot thenewfiebullet. Never used the search option before works great.
Labs
Old Mar 12, 2001 | 08:48 PM
Did you find much that was interesting? I was thinking hard about drilling the clutch weights myself, but I think I may go with a manual clutch conversion instead.
Do you have any other mods done to your Wolverine?
Old Mar 12, 2001 | 10:27 PM
shoesmb's Avatar
Hey let me know how the manual clutch conversion works out. I was thinking about doing it also! What is the talk about drilling the weights out?
Old Mar 12, 2001 | 11:18 PM
By drilling holes in the weights of the primary clutch you will increase the rpm at which the clutch engages. This should make it a bit easier to spin the tires in the mud, and will make it a bit peppier.
As for the manual conversion, I'm still checking out if it can be done while leaving the primary in place. I can't find real reason why it can't be done, but before I start drilling holes in my crankcase covers I want to be sure.
If you're interested in doing a full manual conversion, lots of people have done that, with great success.
Old Mar 13, 2001 | 02:20 AM
Bushbunny's Avatar
Howdy...all you have to do is drill a 3/16 hole near the end of the clutch weights...drill one and use that one as a pattern to do the others...it will change the engage speed of the clutch from 3000 rpm to 3400 rpm...
BB
Old Mar 13, 2001 | 08:50 AM
asfastasu's Avatar
I have a question about this. Is there a gasket or anything that is needed after I pull the cover off? It is the cover that has the clutch ajustment on it isn't it? I don't live near a dealer so I want to have everthing I need before I get it all tore apart and everythings closed.
Old Mar 13, 2001 | 09:16 AM
Camo-man's Avatar
I followed Bushbunny's directions on drilling
the weights. It was pretty easy , and my quad
has a faster tackoff now....good low budget
improvement....
Old Mar 13, 2001 | 09:21 AM
mtecate4g's Avatar
How do you change your wolverine clutch into a manual clutch and where can i get a kit thanks!!
