Yamaha Question
Old Apr 2, 2014 | 12:12 PM
nukacola's Avatar
122.5 main for 87-88.
120 main for 89-95. According to Clymer manual. Get one!
So your main should be a 120 and clean the hell out of your carb to rule it out. It causes most problems in these things. The needles are so tiny. Run carb cleaner through them and spray compressed air.
I always say put in a little inline fuel filter for insurance like I do with a Kohler fuel filter. Part number: #25 050 07-S1
Amazon.com: KOHLER 25 050 07-S Engine Fuel Filter 75 Micron With 3/16-Inch & 1/4-Inch Fuel Line Inside Diameter: Patio, Lawn & Garden Amazon.com: KOHLER 25 050 07-S Engine Fuel Filter 75 Micron With 3/16-Inch & 1/4-Inch Fuel Line Inside Diameter: Patio, Lawn & Garden
Since using that little filter I haven't had any carb problems in about a year or so. The tiniest little **** can cause a world of problems.
Old Apr 2, 2014 | 12:17 PM
nukacola's Avatar
Originally Posted by safooma230s
Check the main jet. If it's bogging out at full throttle, it could be that it's getting too much fuel. My 96 warrior did this exact thing and it turns out someone had put a larger main jet in it without having put on a pipe(or perhaps they removed the pipe and were too lazy to pull the larger jet). IIRC, the stock main for the 350 is a 145.
It could also be that your air cleaner is dirty/clogged as that would create a similar issue(rich), but from the other side(air restriction).
I think the stock main for a Warrior or Raptor is a 145. But for a Moto 4/Big Bear it's 120, depending on year. Most run 120.
Cole Hadden
Jun 15, 2025 09:05 AM
toonces
Oct 16, 2019 12:11 PM
Jul 28, 2015 12:12 PM
coolguy420
Jul 28, 2015 01:54 AM
Jul 7, 2015 11:00 PM
