cam mod
Old May 18, 2011 | 11:36 PM
xYFZ450x's Avatar
Default cam mod
can I do the cam mod on my 2009 yfz 450?
Old May 19, 2011 | 12:27 PM
m.jones101604's Avatar
if its fuel injected you can't touch the exhaust cam. in order to do the cam mod on those you need to get an 06-08 intake cam and install it. that is the cam mod for the fuel injecteds
Old May 19, 2011 | 01:24 PM
xYFZ450x's Avatar
It's not fuel injected it's carbureted
Old May 19, 2011 | 01:27 PM
you should be good than not 100% let me ask my buddy I'll get back to ya
Old May 19, 2011 | 07:12 PM
you will be fine just retart the exhaust one tooth
Old May 19, 2011 | 07:17 PM
might won't to do the zip tie mod to (better throttle responce) while your in there
Old May 24, 2011 | 01:21 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
You can do it if your mechanically inclined. You must be patient and very careful. One slip and you'll be either splitting the case to fish out parts or doing a top end rebuild.
The zip tie mod is in the carburetor. You won't have to tear into it or even remove it. To access it just take the throttle side cover off the carb.
Old May 26, 2011 | 10:47 AM
xYFZ450x's Avatar
Default Cam mod
So I got the cam mod all done and its running good no problems. I took a look at the zip tie mod and Im not going to use a zip tie. Thats to skechy the head of the zip tie hits the cover. And I tried to put the zip tie on 3 or 4 different ways and went out and bought different sizes. Ill just go buy a better spring or use wire seems safer.
Old May 26, 2011 | 11:12 AM
Koopa's Avatar
Congrats. I know exactly what your saying about the zip mod. I did it quite a while back and thought the same thing. Sure enough couple weekends ago I had to re-jet due to a knew exhaust and sure enough I checked and it had slid off. : \
I never did the cam mod so while waiting on my jets to get in I just tore into her. Actually think it was the weekend before your post. Got a little seat time but, didnt have time for much. Had crazy weather here in OK. It maybe (probably) my imagination but, man it seems the sound is different. More like a dirtbike sound. Eh, sure it was my excitement playing with me. I'm still not accustomed to the Barker sound either.
Old Apr 30, 2014 | 10:20 AM
Raymond3088's Avatar
i have a quetion.. there is a difrent on FI and Carb Cams?
