Any Banshee Woods Riders out there?
Old Mar 12, 2001 | 05:51 PM
WhatRULookinAt's Avatar
Hey, any of you Banshee riders out there ride in the woods? And does the bashee handle pretty good out there?
Old Mar 12, 2001 | 06:01 PM
kokl's Avatar
i thought about the same thing when i traded my 400ex for a modded banshee. but, i have no problem in the woods at all. i use the clutch as the throttle to get through ruff tight spots. you just have to keep the engine revved. good luck
Old Mar 12, 2001 | 08:26 PM
AirBanshee01's Avatar
Thats all i ride for now, the shee loves the woods.
Old Mar 12, 2001 | 10:21 PM
WyoRider's Avatar
The Banshee is good in the woods as long as you keep moving. It doesn't take long to overheat from trying to get unstuck or crawling slow over rocks. A 13 tooth counter-sprocket (instead of stock 14 tooth) helps since you don't need the top speed as much as low-end grunt. Some skid plates help if it is rocky too.
Old Mar 13, 2001 | 09:37 AM
sAyIt_fmf's Avatar
Unless it's about 100 degrees out...I have never had my banshee overheat from going slow or fast. I think alot of people overheat from lean jetting...buts thats just my opinion. Maybe I've just been lucky in the 5 years I've had the banshee.
It handles just fine in the woods. I don't think I understand the gripes about the banshee being so bad on the trails.
Old Mar 14, 2001 | 10:13 PM
free1steven's Avatar
To help me through the woods on my Banshee I am using a single carb setup. The throttle response makes it a much easier machine to ride. I use Realtor Bandit tires on front and rear which have proven to be indestructable. I use a 4in. wider rear axle which gives me a more stable ride. What you really want to spend your money on is good shocks that are servicable. That will make you a better rider and the ride will be more enjoyable.
Old Mar 15, 2001 | 10:09 AM
jg40178's Avatar
I ride quite a bit of woods on mine. I didn't like slipping the clutch all the time; shaving the head .040" took care of it. Gave me lots of bottom end (still not 4-stroke bottom end, but much better than stock.) I also have trouble with overheating when moving slow. I don't think it's the jets either. It did it stock and now it does it after being piped and jetted. It is much better now that the head is shaved, but it still does it. Though it sounds crazy, I have wooley boogers on the rear of mine now. They help me a lot in the woods; they let the *** end slide around tight corners better.
Old Mar 15, 2001 | 12:37 PM
SaMs0nOLD's Avatar
I race Harescrambles with my banshee, and I have no probs in the woods. The trick is to set it up for woods riding. Drop to 13 tooth front sprocket. Raise the compression by shaving the head. Get pipes like LRD or the 2 into 1 kind (I went with LRD). Better reeds. Then you should be all set.
Old Mar 16, 2001 | 09:46 AM
AdrenalinFreak's Avatar
I ride my banshee in the woods. Right from stock bike the only thing that I consistantly ran into problems with was large mud holes. Not overheating in them, Just getting stuck. I do not have to fan my clutch alot, At least not that I remember (In other words you get used to it real quick) I can get my bike into some extremely gnarly situations, But for all around trail riding it is very good, and extremely fast. Skidplates are a must, And shocks are definatly on the list of stuff to do.
Old Mar 16, 2001 | 01:41 PM
discharge's Avatar
i set mine up for woods......2 into 1 moto-fast pipe, trinity 2 into 1 carb kit, and works suspension.....all i need now is a wider axle and i should be done......never had mine overheat
bigred20653
Oct 2, 2015 10:05 AM
Sep 30, 2015 01:37 AM
Honski250r
Sep 26, 2015 09:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
