Compression Too High?
Old Oct 16, 2011 | 11:36 AM
thomtwo's Avatar
Default Compression Too High?
I did a head compression check on my '94 Kodiak 400, thinking this maybe a part of the Cold Start trouble.
It's been flooding out the plug and spraying fuel into the intake filter air box.
I have replaced the float needle and other carb parts with a K&L Carb Kit first. I've rechecked the float height twice. +.051"
After the engine is warm it starts fine, but cold, it only floods out.
Today, just to get it running I took my heat gun to the cylinder head and spark plug hole for about 15 minutes.
Then it started.
Here's the compression reading. The range has me very confused.
My Service Manual gives no info on what the Cold Pressure reading should be.
Cool Engine read 90 psi
Warmed up Engine read 170 psi
The Service Manual says the Warm Engine should be...
- (Standard)=131 psi
- (Minium) =105psi
It also says reading above maximum...
1) Inspect cylinder heads, valve surface, or piston crown for carbon deposits.
Man, am I confused and lost...
Old Oct 17, 2011 | 02:12 PM
JLsparky7's Avatar
170 is really high... Maybe its your gauge?
pgamboa
Dec 24, 2023 11:52 AM
2quiker
Mar 22, 2022 08:36 PM
bvolks
Sep 13, 2015 12:57 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
