Steering too tight on 2005 Kodiak
Old Sep 2, 2012 | 11:41 AM
Gemenii22's Avatar
Default Steering too tight on 2005 Kodiak
Hey folks. My 2005 kodiak has been through some rough riding, and after having the front wheel bearings replaced, I got it back and the steering is waaaay over tight. As in having to strain to steer. I think I know how to fix it, but I'm having trouble finding the correct size tool to remove the nut at the base of the steering column. Has anyone had a similar problem, and can suggest a tool that will fit? There's not room for a deep well socket, and I've not got a wrench that will fit. Any ideas will be greatly appreciated, and thanks in advance for yalls help
Old Sep 9, 2012 | 07:09 AM
Dick-quad's Avatar
I just helped my brother replace bearings on both his front tires on a 05 400 kodiak. The only part of the steering we touched was poping the tie-rods ends. I wonder if maybe the brake calipers ( which get removed and replaced) hose is not in the right position(?). If you had a shop do the bearings, i would take it back to them as maybe they broke (bent) something. Is it still tight if the front end is off the ground? Just some thoughts!!
salixair
Nov 3, 2015 08:25 AM
YankeeRebel
Oct 6, 2015 06:44 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Brandon400
Sep 5, 2015 08:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
