Yamaha Timberwolf Melting Down????
Old Nov 16, 2012 | 08:32 PM
ShelbyGT660's Avatar
Default Yamaha Timberwolf Melting Down????
Since I have had this Yamaha Timberwolf it has had the problem of blowing oil out the breather, Also if I am running it down a road and look back I can smell oil, So I assume its burning it as well, Plug is a light brown in color. Goes through about a quart in about 7 hours of run time, Some of which ends up in the breather box, How can I remedy this? It has good compression (Rated is 128PSI) 125PSI. And starts without problem with the electric start. I am out of ideas and the cost of oil is killing me. It also has a new problem, It seems to be running wayyy to hot, Its melting the o-rings on the valve covers and starting to melt the plastic on the oil dipstick >_> Its also now burning oil big time when its hot, I am guessing its due to the oil thinning? Or it blew the oilring out from overheating, It makes a cloud of oil smoke at around 5000RPM once hot. I am running out of ideas and do not have a ton of money to throw at it.
Old Nov 17, 2012 | 10:13 AM
Doctorturbo's Avatar
GOT BOOST!
You are going have to re-ring it. You are building up CC pressure because your rings at toast and that is why you are blowing oil out of the breather.
Old Nov 17, 2012 | 11:52 AM
Well, Lots of bad news -_-
2quiker
Mar 22, 2022 08:36 PM
Sep 17, 2015 03:06 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
