big bear 400 help
Old Feb 27, 2013 | 05:44 PM
Nelson's Avatar
Default big bear 400 help
my big bear will be running fine then acts like its loosing power and it will start hissing untill back fire then runs normal it is getting worse now but after it will back fire a few time it runs fine it sounds almost like the pipes blocked but i dont think thats the problem
Old Mar 1, 2013 | 06:11 PM
Nelson's Avatar
need help please
Old Mar 1, 2013 | 07:38 PM
oldmattb's Avatar
This is mainly a boost so someone else will see your thread. My newbie guess is a piece of crud in the carburetor bowl that is getting sucked up against the main jet, making the mix too lean. When the vacuum drops, the crud drops and you run OK again. One can loosen the carb and remove the bowl without removing the carb from the quad. I saw a new carb on ebay for about $100 shipped.
I just bought a Big Bear 400 (2003) Tuesday. It set up for a few years. It will run OK under throttle, but won't idle. I have a friend coming over tomorrow to help me. I also got two Honda Recons - a quick carb clean and they run fine.
I hope you get a good answer soon, amigo.
Old Mar 3, 2013 | 06:28 PM
Nelson's Avatar
thanks il try that
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
