New Raptor 350 burning oil
Does anyone know what would cause a relatively new ATV that was bought approximately 1 year ago new as a leftover 2009 model to burn oil? I followed a well regarded break-in procedure and I don't beat the quad to death half the time so I don't see why the ATV is burning oil.
I first noticed it and I believe that it occurred after the first oil change at Little Sahara last summer, it was around 90-100°F and I was pushing the engine hard up dunes. It only occurs after you advance the rpm's following the let off of the throttle a little white smoke appears from the exhaust. When the oil is at a lower level (about 1mm above the point where you need to add) it doesn't produce visible smoke and appears to burn considerably less oil. Does anyone think that it has something to do with the piston rings, valve seats/seals, valve clearances or possibly oil level. Thank you in advance for any replies.
What brand and type of oil you using?
Thanks for the response, I use Yamalube 10w40 oil, its just weird, the motor only has around 50 hours on it.
What you have to understand is these are not one of race motors. These are production motors built very quickly on a production line.
Once in a while one gets through that is not quite right. Yours could be that one.
I might throw an oil cooler on the machine since it only smokes when hot and see if that will help, but at this point I'll probably just wait until it needs a rebuild which will be a long time.
I agree with you 110%.
But, as Scoot pointed out; and rightfully so, if for some reason a bit of sand or dirt or water gets in that engine, things can get loose in a hurry.
I wouldn't really worry about it too much unless it's fouling a plug or burning tons of oil.
Good luck!
Good luck!
Good luck!
Good luck!
No, it doesn't, but I think any air cooled engine should have one. Especially since the Kansas summers are not very cool.
