yamaha warrior help
Old Jun 20, 2013 | 05:18 PM
mrmoose's Avatar
Default yamaha warrior help
ok so long story short, i got a 99 warrior cheap, BUT it had a lot of problems. i first had to spend 100 on a new cdi, then i found out its missing a relay, i am assuming its the starter relay, NOT the solenoid. solenoid clicks when key is turned on but starter wont engage when starter button is pressed. i jumped the starter and it turns over great but no spark so i am assuming the relay would supply power to the coil or stator? it has one relay on, so its only missing one, is there a way to bypass it? thanks! pics...
Old Jul 13, 2013 | 11:06 AM
cano86's Avatar
About that 2 wire plug in the front it shouldnt be your problem I have mine disconnected as well and mine works fine, As for the relay missing I belive it to be your problem as that is the starting system cutoff relay. hope you get fix
2quiker
Mar 22, 2022 08:36 PM
Sep 17, 2015 03:06 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
