About to buy an 07 Wolverine.
Old Mar 13, 2014 | 12:12 PM
TLC's Avatar
TLC
Good 16 points tips below but some are not deal killers.
1. Have a friend or the owner help you raise the ATV up and stand it on the rear grab bar. This will allow you to inspect the undercarriage for any serious dents or damage.
2. Look closely at the frame, especially the shock mounts, A-arm mounts and intersections of frame components for any signs of rust. This is normally a sign of a stress crack and would require welding and repainting.
3. On 4x4 ATVs, inspect the CV joint boots. They should be in excellent condition. Any crack or tears will allow water and dirt to enter and cause costly repairs.
4. Also on 4x4 ATVs, if possible remove the front and rear differential inspection plugs. If the gear lube looks like chocolate milk the oil is contaminated with water and there could be damage to the bearings.
5. Check the engine oil to see whether it looks contaminated.
6. Shine a flashlight into the gas tank and look for rust. Yes, a gas tank can rush, and rust can cause carb problems.
7. Raise the ATV and support the front of it with jack stands. Then try to move each front wheel in and out from top to bottom and side to side to check for worn wheel bearings and ball joints. Do the same for the rear.
8. With the ATV on the ground, move the handlebars back and forth. This will identify worn tie rod ends.
9. Remove the seat and take the air box lid off. This is often overlooked. An air box can collect water and damage an engine. A clean air box and filter is a good sign.
10. Check all head lights, tail lights, the engine shut off switch and key switch.
11. Check the hand, foot and parking brakes. Do they operate smoothly or stick? Check for damaged or cracked cables.
12. Check the exhaust. Has the spark arrestor been removed? Almost every state and national forest requires that you have one. You don't want to get to a forest and then find out you can't ride because you don't have a spark arrestor.
13. Check for worn out tires or tires full of plugs. It's not really a problem, but worn tires or plugs should be a negotiating point on price. And the tires should be replaced with new ones. If you have never taken a tire off a wheel, don't do it. They are extremely hard to remove. It's much easier to remove a car tire from a wheel than an ATV tire.
14. Look closely at the front or rear sprockets. Each point should be uniform. If they are worn more on one side or have a hooked appearance, a new chain and sprocket set is in order.
15. After you buy a used machine, it's a good idea to change all the fluids so that you know you have fresh oil, etc.
16. Ride the machine.
A little ride down the street, to heck with the neighbours, will tell you if the exhaust (#12) is ok and the motor is damaged(#9).
How does a damaged motor not show itself through excessive smoke, strange sounds or vibration or power delivery.
I never rode something with a damaged engine that behaved exactly like a non damaged engine.
I,m sure I have a dirty air filter currently because I have not cleaned it in a while but the motor is 100%.
That's what the air filter is for to catch dirt. Its more like take the filter off and see if the inside of the air intake tube is clean,that means the dirty filter did its job well.
Old Mar 13, 2014 | 01:08 PM
quadsr4me's Avatar
So there are a couple '07 450 wolverines in my area. One is asking 3200 and the other 3500. Both claim to have under 900 miles on them, have good tires and one says it's "super clean". Again, these are asking prices.
Old Mar 13, 2014 | 01:49 PM
TLC's Avatar
TLC
I do not trust speedo they can be disconnected but if the ATV still has its stock tires and they are in good shape that tells you it has low miles . ATV tires wear out rather quickly.
Nice machine, same motor the 450 Grizzly uses but with the 350 Grizzly's chassis, drivetrain, suspension and tranny, and with sporty plastic and no racks.
I know those two ATVs are very reliable.
Old Mar 13, 2014 | 02:26 PM
Endangered Species's Avatar
Thanks for the help everyone, but it turns out he doesn't have a title or a registration for the Wolverine. It's a "He bought it from a guy, who bought it from a guy", type of situation. He kept insisting I could get a title from DMV with easy by filling out some paperwork and jumping through some hoops, the same hoops he decided to avoid by not getting a title. So I decided against it. Thanks again, I will keep looking.
Old Mar 14, 2014 | 02:56 AM
  #15
TLC's Avatar
TLC
No problem just reduce the price by a $1000 and only ride in the deep deep outbacks where nobody cares about paperwork.
Old Mar 14, 2014 | 05:16 AM
  #16
I told him I would give 1500 for it and he said "no way it's worth way more", at which point I laughed and said good luck. My 46 acres boarders state land and we ride the trails all the time. Unfortunately there are to many En-con officers running around, so I need to be legal. I'm getting to old to run from the fuzz anymore.
TeamCovert
Jan 25, 2001 10:22 PM
bigman
Jan 11, 2001 09:52 PM
Digs
Dec 6, 2000 07:33 PM
MDP49
Feb 2, 2000 08:57 AM
