1999? Yamaha Wolverine 350cc 4x4 Help
Hi guys,
Just came home with a 1999? Yamaha Wolverine 350 4x4.
It had its tires previously upgraded to 25" (decent life left), and has the Warn 424 select kit installed (which I'm quite happy about).
The reason I have a question mark beside 1999 is it was advertised as that, has ownership for that but it reads 11/98 on the sticker on the frame. Is it still a 1999 because it was manufactured so late in the year?
Second, the starter is gone on it but starts well with the pull cord so that isn't a HUGE issue at the moment. A friend of mine said rebuilding them is not too difficult and much cheaper than replacing so I'll likely go this route if possible, down the road.
Third, there seems to be oil leaking out of the top end of the engine. The previous owner said he kept checking the oil level and it would almost never go down, so he didn't bother fixing. I like my toys in tip-top shape so I would like to deal with this issue. I'm guessing I'll have to replace all the gaskets and seals in the top end, which doesn't look like an overly costly repair. Particular aftermarket brand or type recommended before I just grab whatever I find on rockymountain?
Other than that, the bike starts and runs OK, shifts through the gears, moves from 2wd to 4wd fairly easily so I'm overall happy.
My main concern is the oil leak and getting that problem out of the way in case it is an indicator of something more serious.
Again, anyone with experience tip/tricks are always appreciated. I'm no mechanic, but I do enjoy tinkering with small engines and am not completely useless in the garage.
Thanks all!
- - Mike
Thanks all!
- - Mike
You have a 99 model. Most manufacturers come out middle/late summer with next year models. My old 92 Honda had a manufacture date of 9/91 but the plate shows it's a 92 model. Gasket kit are available on ebay if needed. May be some out there cheaper than this.http://www.ebay.com/itm/95-09-Yamaha-YFM-Wolverine-350-Top-End-Gasket-Kit-NAMURA-/381105998175?pt=Motors_ATV_Parts_Accessories&hash=item58bbb0095f&vxp=mtr
You have a 99 model. Most manufacturers come out middle/late summer with next year models. My old 92 Honda had a manufacture date of 9/91 but the plate shows it's a 92 model. Gasket kit are available on ebay if needed. May be some out there cheaper than this.95 09 Yamaha YFM Wolverine 350 Top End Gasket Kit Namura | eBay
1. https://www.rockymountainatvmc.com/p...ket-Kit?v=1476 Tusk Brand - $19.99
2.https://www.rockymountainatvmc.com/p...ket-Set?v=1476 Cometic Brand - $26.99
3. https://www.rockymountainatvmc.com/p...ket-Kit?v=1476 Pro X Brand - $31.99
I just didn't know if others had good/bad experiences with any brand in particular. Reading the reviews on their site it looks like people are quite happy with the Cometic brand, unless I hear otherwise I might go with that.
So here are some pictures of the oil I'm seeing (it looks a lot worse because I sprayed some engine cleaner on it to try and clean it up a bit).
I guess my question is, will the top end gasket kit fix this or could this be a bigger issue? I plan on busting out my compression tester, but for now a safe place to start would be replace the top end gaskets?
Also, since I have never done this before...I'm assuming the complete removal of the engine is necessary?
Thanks again!
Nasty! I'd clean this sucker up to where it's spotless and then you can see where the oil is coming from before I'd tear it down. May be as simple as leaking valve cover o-rings or cam cover plate leaking oil everywhere.
Looks like the value cover Oring gasket is the problem,They let it go so long it made an mess on the engine,,May try to replace them first before an top end teardown IMO
On another note, any suggestion on oil (synthetic vs non) and also thinking I would change the gear oil in the front and rear. Any particular oil for that recommended? I'm going to also look for the Clymer Manual for this bike tomorrow. Should I get the service manual as well or Clymer manual the way to go?
