Thoughts On 01 Wolverine For Property?
Old Apr 27, 2017 | 07:53 PM
pjr710's Avatar
Default Thoughts On 01 Wolverine For Property?
I need a quad to get around 40 acre area, it's wooded, rocky, and has a field that gets a little wet.
I assume I might be towing trees or something if needed. But overall the land is flat with the occasional large rock or tree I might run into.
How would an 01 Wolverine work for something like this?
Old May 3, 2017 | 02:30 PM
NCLandBroker's Avatar
Yep, a 01 Wolverine would probably suit you just fine. Not the best for dragging large trees, but it should have no problem toting or towing light or medium size loads.
Old May 3, 2017 | 05:45 PM
Ajax's Avatar
The Wolvie would be ok for what your talking about but they tend to be more on the sport side of the sport/utility they were labeled as.
Maybe a Grizz or Kodiak may suit your needs better on the utility side.
I have a 97 Wolverine 350, high comp piston and hmf exhaust, does great in the mud and trail riding. Due to the taller gears and lighter curb weight on the wolverine I tend to use my Foreman 450 for the labor end of things. Not that the Wolvie couldn't do it its just the 450 TRX seems more equipped for it.
Old May 3, 2017 | 07:09 PM
greg74's Avatar
If you really want a semi auto 4x4 I'd look for a big bear 400 4x4
