My Yamaha warrior 350 neutral and reverse problem.
Old Jun 23, 2017 | 05:48 PM
ChrisYamaha's Avatar
Default My Yamaha warrior 350 neutral and reverse problem.
I have this 2003 Yamaha warrior 350 and just starting yesterday this neutral problem started. When my quad is on, it goes into all the gears but when I try to put it into neutral( between 1st and second) it doesn't go. Its really hard to lift up the gear and then it goes into second. When I turn off the quad though, it goes into neutral just fine. Why is this and how do I fix it? Also, my reverse lever goes into reverse fine but when I try to put it back into forward, it takes a good few minutes of back and forth movement and pulling up on it until it finally goes into reverse. Please help me with these problems.
Old Jun 24, 2017 | 08:23 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
How is your Idle speed? Try lowering it. Could be a clutch adjustment or the clutch is worn.
Old Jun 25, 2017 | 05:55 PM
It was the clutch. It was way too loose and now engages.
