1996 Wolverine
Old Oct 8, 2017 | 08:40 PM
dnm48's Avatar
Default 1996 Wolverine
I have a 1996 Yamaha Wolverine ,it started out not running smooth thought it was the carb. Took it off and cleaned it ,put it back . Now it starts up and will run ,but once it gets warm it loses all power and eventually dies. It will start back up and same thing happens again. Can anyone help me. Thanks
Old Oct 8, 2017 | 08:51 PM
Yamahaulinass's Avatar
Default Fuel?
Check if it has a screen in fuel valve. Check if problem is the same if is on and in the reserve position. Might have fuel delivery blockage.
Old Oct 8, 2017 | 09:20 PM
dnm48's Avatar
put a new one on when I did carb because it leaked
Old Oct 8, 2017 | 09:21 PM
dnm48's Avatar
also put a new gas line from fuel switch to carb
Old Oct 8, 2017 | 10:44 PM
Default Spark
You can eliminate elec problem if u get it to die and it won't start,pull plug wire and check for fire while cranking
