banshee wont start
banshee wont start
i try turning on the quad and does not want to turn on at all i rebuilt the carbs set float height to 21 mm and still nothing i have a 300 jet in it idk if that could cause a issue it just has pipes no airbox and carbs are bored out to 28mm i think unless that is stock im new to this quad got it not so long ago and started doing it not so long ago
No airbox is not helping either. Airflow control is needed with the airbox on as without it might cause an initial lean condition. Check spark and condition of plugs, if they are wet with fuel then probably fouled out. Being a two stroke everything needs to be set just right for the conditions to make them run.
rjchristensen
03-16-2023 06:12 AM
