Front differential 1999 Yamaha Kodiak 400 4x4
Does the front differential take gear oil or transmission fluid or what have you, the oil filter has 2 hoses that run off of it and it goes to the front of the bike. I can't see where it goes from there but I don't know if the engines oil runs as the diff oil? Am I correct
Those two hoses will go to an oil cooler. I always use 90s gear oil in the diff. A while since I did one but there is a filler cap on the side of the diff. Not sure if there is a level plug below it, or if you fill to the filler hole. I seem to remember an inordinately long level plug, though that could be a Big Bear or Bruin.
Originally Posted by merryman
(Post 3402186)
