2006 Bruin high end bogging
Old Nov 19, 2018 | 07:04 PM
James Merritt's Avatar
Default 2006 Bruin high end bogging
Im new here and this is my first post, I have had to read a few posts to figure out bikes I was working on before though. So here goes nothing…
I’m currently working on a 2006 Bruin 250. The guy brought it to me and said that neutral, 1st, and 2nd he has full range on the throttle, 3rd 4th and 5th the throttle has to be “babied”. He had replaced the carburetor with an OEM carb and continued to have the same issue. He also replaced the spark plug.
i tested the unit and found that first and second have full throttle range, once you shift to third it feels like the engine is governed unless you ease into the throttle. If you need the power and open the throttle quickly, it loses rpm and power. It won’t stall but it runs roughly just above an idle rpm.
I found an air leak on the carburetor joint and replaced it. I have tried 2 different spark plugs and various gaps from .028” to .033”. I have tested the resistance on the ignition coil and the spark plug cap. All was within spec. I’ve checked the valve lash clearance, also within spec. Fresh gas and good flow from the tank to the carb. I’ve inspected all vacuum lines and the throttle and choke adjustments. The choke being on or off doesn’t affect the issue at all.
Many ideas before I give up and send him to someone else???
thanks!
Old Nov 20, 2018 | 06:22 AM
Jered651's Avatar
OHM out the stator. Might be getting weak.
Old Nov 20, 2018 | 01:20 PM
Timbo2500's Avatar
I would think if you could rev through high Rpm's while moving in 1st and 2nd gear then that would most likely rule out a fuel problem. Per the above post it could be electrical. If the stator checks out good then you may want to try swapping out the CDI. I had a similar problem with the Big Bear 250 (same quad, different name) and I purchased a new CDI on ebay (non OEM) for $90 and it fixed my problem. Mine would not let me rev past mid throttle before it would start coughing like it was a fuel problem. I tried everything until I finally replaced the stator. These don't have a rev limiter on them so that wouldn't be the problem. Good luck.
wildwest1011
Mar 12, 2007 12:22 AM
Hightower
Jan 23, 2003 05:58 PM
scottd
Sep 16, 2002 07:34 PM
opiek
Apr 30, 2002 04:21 AM
