Turbo Raptor
Does anyone have any detailed info on the Turbo Raptor that Mr. Turbo was working on? www.mrturbo.com
Quoted from the paper I have.....
"Your turbo charging a raptor?.....are you guys insain?" The answere to this question? YES! "That's my job" says Terry Kizer.
So how much power does this new "Bad Boy" on four wheels need? "Well, about double should be a good start" says Kizer. The leader in motorcycle turbocharging, Mr. Turbo celebrates its 21st year by "getting dirty". Nothing's more fun than big power in dirt. The new Raptor takes to turbocharging very well by increasing power to the rear wheel's by as much as double and beyond, SO HANG ON!!!
The turbo system mounts neatly in an inconspicuous location, inside the body work making a very clean and easy to install package. The system can be installed by anyone with basic hand tools in as little as a few hours.
"THE SECOND YOU STICK THE THROTTLE, YOU'LL BE WEARING AN EAR TO EAR GRIN....GUARANTEED!
FEATURES
TURBO: Manufacturd by Aerodyne (one of the most state-of-the-art turbo's on the market) roller bearing shafts, variable vane impellers, self-contained wastegate, internal oiling--requires no external oil source or plumbing.
EXHAUST SYSTEM: A Mr. Turbo exclusive, mandrel bent steel tubing, TIG welded, ceramic coated for appearance and protection.
INDUCTION SYSTEM: Billet intake spigots and 6061 aluminum sheet metal manifold, hi-temp silicon hoses.
FUEL SYSTEM: Modified Kehin CU carb's, special turbo set by Mr. Turbo, hi-flow fuel pump and fuel pressure regulator, K&N filter.
FASTENERS: All, nuts, bolts and washers are supplied in stainless steel. System is complete with all gaskets, hoses, wiring, etc. for complete installation.
Mr. Turbo
4014 Hopper Road
Houston, TX 77093
Phone: 281-442-7113
Fax: 281-442-4472
www.m-r-t-u-r-b-o.com
(take out hyphens)
FEATURES
Mr. Turbo
4014 Hopper Road
Houston, TX 77093
Phone: 281-442-7113
Fax: 281-442-4472
(take out hyphens)
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
